600 rev B on eBay
Post here to share listings on auction sites, classified ads, and other notices on the web regarding equipment on offer.
600 rev B on eBay
Post by BillO » Fri Oct 12, 2018 5:20 pm
https://www.ebay.ca/itm/Vintage-Ohio-Sc ... rk:46:pf:0
A bit on the pricey side though. A couple of key caps seem to have been replaced.
Re: 600 rev B on eBay
Post by dave » Sun Oct 14, 2018 6:04 pm
This seller, vintagecomputermuseum, is a veteran seller of vintage computer systems, and will maximize the price whenever possible. Although he claims he has no power supply, that's a bit hard to believe. If there were any way to show it working, he would do so. More likely, it's been tested and doesn't work.
However, the Rev B models are harder to come by, and this one looks to be at least in decent cosmetic condition, aside from the two missing keycaps. I agree it's on the pricey side.
Post by BillO » Sun Oct 14, 2018 7:45 pm
Indeed. I bought a SYM-1 of him back in 2015. He had 2 of them and one came with some weird wiring harness attached to it. That's the one I bought because he accepted my offer at a reasonable price ($225 or so). The other one, much cleaner went for $499. All that aside, the add read "When powered up with a 5V power supply the power light illuminates"
So, yeah, he could test if it he wanted to.
The one I got did not 'work' when it arrived. It had some end-user EPROM in it and the default addressing jumpers had been changed. Once I undid the changes, removed the odd wiring harness and end-user EPROM it worked fine. However, he is a little misleading with his ads.
Post by Jeff » Mon Oct 29, 2018 7:31 pm
The Crystal is missing, also. So , No..it would not work if it was powered up.
