Building the KLyball 600D
Re: Building the KLyball 600D
Post by waltermixxx »
Here is the "final" build: (waiting on space bar stabilizer from amazon). Soldering the keys in was not too much of a hassle,
soldered in 1 pin of each switch, then adjusted each key straight and resoldered the pin, and then the second one. :)
That looks fantastic!
Thank you :)
Colour add on card is next.
going to point to point solder this, and see how I make out. :)
Congrats!!!
/J
Serial port Settings for the REV. D.
to use the 600 REV. D at 9600 what changes need to be made?
pin 11 to 11, was changed to pin 2 to pin 11. Just wondering what
modifications need to be made to run at 9600? :)
(It's Bluetooth time!) :)
Cheers. :)
Steve Provided the info:
the mod is the same, except no track to cut, Pin 2 of U30 to Pin 2 of U57
and that's 9600 baud. :)
Don't forget the j3 config is different the info is back in the thread
I will hard wire it for 9600 baud and just serial out. Yup I saw the post you were talking about with the switch. :0). Serial port testing later today.
Please link the info/thread.
/J
here is the link:
http://www.osiweb.org/osiforum/viewtopi ... 0&start=23
this same thread page 3 looks like the 23rd post. :) this link should take you right to it. :)
Thanks, Walter.
/J
