Error 9 causes
Error 9 causes
Post by lowrybt1 »
Looking for some diagnostic help. One of my MPI B51 drives has started throwing off an Error 9 whenever I try to read/write to a track. As far as I can tell (trying to listen carefully), the head is not seeking/tracking. I suppose this could be due to failure of some component on the logic board (will try to swap in a spare) or the tracking motor. I’m also wondering if it could be a PSU issue. Not supplying right voltage and/or current.
Thoughts?
Re: Error 9 causes
From the ref card, Error 9 means the OS can't load the track header within one track revolution. Some questions to clarify the problem:
2) Does the problem only affect one drive, or both? If only one, can you boot from the offending drive?
3) Does this happen on every track, or some of them?
3) On a given track with the error 9 problem, does the read or write sometimes work, or always gives the error?
4) Do any disks boot to OS65D / BASIC?
Re: Error 9 causes
Post by lowrybt1 »
As always, thanks Dave.
The problem affects only one drive and I can’t boot from the offending drive
Happens with every track
Always an error on R/W attempt
Disks boot on two known working drives.
Tom
