FlashFloppy + Gotek and OSI
Re: FlashFloppy + Gotek and OSI
Post by nama »
Exciting times
Post by nama »
Here is a little teaser...
Yep, that's a Gotek drive.
Congratulations! So the hfe format really is the flux transitions without any knowledge of disk formatting! This has been a dream for many OSI users for so long. It will breath new life into many OSI systems.
If we can:
  1. convert back and forth between the OSI image files and hfe format, and
  2. easily write OSI disk images to physical media
then the loop will be closed, and we can create Gotek images from physical disks and vice versa, without a kryoflux. The raw images are a good fit for OSI, since they are compact and can be dumped and (theoretically) read back in real time by the 1MHz machines.
Thanks for pushing through on this!
This is awesome. Can you please post a dump of the Kryoflux output from a 65D disk. Just curious to see the raw file format.
Looks like you need an LCD on the Gotek if you wish to have your images organised in folders ?
