Building a C4P Replica
Re: Building a C4P Replica
Certainly with you on that Dave.We have a great team on the forum with various projects coming along well.
I'm back on board these days can now get my replica boards order sorted. I would be interested in 1 keyboard at least. Data separator and memory boards and backplanes etc I need to revisit just what I need there also and bundle it all. Spoiled myself with a new soldering iron and de -solder station for my retirement.
multivac
Post by multivac »
I would be interested in two keyboard PCBs to use Cherry keyswitches. Would there have to be a workaround for the latching Cherry keyswitches that are no longer made or would we have to search for NOS?
I would be interested in the correct keycaps too.
Do we have a solution for the space bar hardware; such as a 3D print of the plastic components and sizes for the wire piece?
I have pads to install a switch , if a locking switch can't be found.
the layouts for the 600 and 542 with mx keys have holes for these cherry parts and the space bar has the sockets
4-2x-1-6-25x-1-Sets-Mechanical-Gaming-Keyboard-Cap-Stabilizer-for-PCB-mounted-Keyboards.jpg
4-2x-1-6-25x-1-Sets-Mechanical-Gaming-Keyboard-Cap-Stabilizer-for-PCB-mounted-Keyboards.jpg (47.92 KiB) Viewed 13290 times
froso
Post by froso »
multivac
Post by multivac »
I can do a search for the MX spacebar solution however is there a size I should be looking for?
just to check the images; 542-new is the MX version and 542-old is for the original style of keyswitch?
For the non-latching MX version of the Keyboard how is the locking switch implemented?
You have a PM
Its eight key spacing
gekaufman
Post by gekaufman »
I'd be interested in a board if you do a run. Thanks!
Klyball wrote: Sat Aug 11, 2018 10:43 pm I could do a small run of 5-10 boards if there is interest
Is the Cherry MX key the same footprint as the original OSI key. ie do they fit the original 600 and UK101 board ? :?
I have a run of 542c from scans modified for cherry keys coming in fri or mon. Let me know if interested be around 25 a board. PM me for shipping
Digikey has switches for around .65 a switch
Grant, OK cherry keys dont fit right. Can your 542c attach as an external to 600 board ?
