A Source for Molex connectors?
Post by Jeff » Fri Apr 05, 2019 2:07 am
The 48 pin backplane consists of 2 parts:
The 12 pin edge connectors: Molex 09-52-3123
The 12 pin male connectors: Molex 26-48-1125
Does anyone know of a cheap source for these? Digi-Key is pretty expensive right now.
Re: A Source for Molex connectors?
Post by dave » Fri Apr 05, 2019 5:59 pm
It depends on the definition of cheap. For some reason, the Digikey search is hanging right now. Mouser has both in stock, although the 09-52-3123 is designated end-of-life, and is slated to be discontinued by the manufacturer. They are both about $1.75 ea. Octopart is a good place to search for parts. I don't know of any cheap surplus caches of these parts.
Post by dave » Fri Apr 05, 2019 6:15 pm
test post
Post by Jeff » Fri Apr 05, 2019 7:28 pm
I have discovered an alternate part on DigiKey: Use the 24 pin one and cut it in half!
Digikey PN: WM50007-24-ND. $2.30CDN each when buying 10+ which works out to $1.30 each... which is tolerable.
I am still looking for the edge connectors.
