Full writeup here: http://www.glitchwrks.com/2019/07/30/47 ... -second-c3
So, on Friday, I started repairing this OSI 470 floppy controller:
I've had it for years, it came with the Challenger III I've got, in the C3-OEM case -- the one I use for most of my OSI hacking. It didn't work, but I happened to have a 470B from another system that did work, so the 470B has been in the C3-OEM case ever since. Last week, I came across this board while doing some cleaning-up in the shop and decided to fix it...I mean, it's such a simple board, right? How hard could it be?!
Well, I ended up building another Challenger III in the process:
The above system was operated basically as shown above (but with more cards) by its previous, original owner. He just had the backplane screwed down to a plank of wood, on a shelf, with modular power supplies and the CD-74 hard disk it lived with. There were a pair of 8" floppy drives in an OSI cabinet on the bench below the shelf, where they were easier to access. I have all the cards for said system, but since there was no case, I'd never really done much with it, and used boards from it to get the C3-OEM system going.
I decided to build up a bench system Challenger III since it looks like the C3-OEM backplane has a cracked trace or solder joint. That was why I was having weird RAM test failures with the GW-OSI-RAM1, using Mark's new universal RAM test. But, that didn't fix all of my 470 weirdness! It's documented in the writeup linked above, but basically a weirdly-faulted 6821 PIA was causing the 8" floppy drive to go past track 0, probably hitting a mechanical limit but still showing as on track 0. What a nutty problem!
A Weird OSI 470 Repair
- glitch
