Spacebar stabilizer
Spacebar stabilizer
Happy holidays everyone!
I am wondering, can those folks who have built up keyboards using keycaps from Grant (Klyball) or from me confirm a cherry MX-compatible spacebar stabilizer?
Re: Spacebar stabilizer
I use these , both my boards have the holes for the mount , just need to make a longer rod
Ah, so there's no premade solution.
What material did you end up using for the replacement rod, and how did you bend it--simply pliers?
gekaufman
Post by gekaufman »
I found Klyball's link from a while back...
2x 6.25x PCB Mount Mechanical Keyboard Cap Stabilizer For Cherry MX Switch
https://www.banggood.com/2x-6_25x-PCB- ... rehouse=CN
$7.49 shipped
