580 8 slot backplane.
gekaufman
Post by gekaufman »
Before I make a dumb mistake, I just wanted to confirm that the connectors mount on the Blue side of the PC board?
- Gary
Re: 580 8 slot backplane.
Can you post a picture?
gekaufman
Post by gekaufman »
Sure, I think the pins mount as shown on the blue side.
= Gary
dave wrote: Sat Feb 29, 2020 1:45 am Can you post a picture?
Blue - Top.jpg (337.06 KiB) Viewed 7366 times
The connectors are inserted on the blue side, as you have in the picture.
I would have thought that the solder mask would be on the solder side of the board.
Good luck!
gekaufman
Post by gekaufman »
Dave -
Thanks for confirming that. I was also confused by the solder mask on the top and didn't want to make a colossal goof!.
- Gary
dave wrote: Sat Feb 29, 2020 4:21 pm The connectors are inserted on the blue side, as you have in the picture.
Good luck!
CommodoreZ
Post by CommodoreZ »
What a beautiful board. I look forward to seeing this in operation.
Not to derail your thread or anything, but may I ask what the intended function of the logic chips on this backplane are for? I can't say I've gotten too close to larger Challenger models to see for myself, and until now I thought the backplanes were all purely passive.
Superboard Replica (400, 420C, 440) | C4P (502, 540) | Mini OSI-300 | https://www.commodorez.com 🌵
gekaufman
Post by gekaufman »
Derail away!
Dave and Jonathan did a great job making this board available. It is a very thick / stiff material so has a nice feel.
The only documentation I've located is in the OSI Appnote #2, http://osiweb.org/manuals/OSI_appnote_2.pdf
Looks like the logic chips are drivers to extend the bus, and are 7417's. There are also spaces at the bottom for pull-up resistors.
- Gary
CommodoreZ wrote: Sun Mar 01, 2020 8:22 am What a beautiful board. I look forward to seeing this in operation.
Post by glitch »
Wow, sure looks like I ran that the wrong way around...I wonder if that's my goof, or the board fab?!
