Superboard Assy Manual Test Procedure 2
hsnewman
Post by hsnewman »
I am slowly building the Klybal superboard 2, and am on page 19 of the Superboard Assembly manual. It says:
"All of these combinations except Pin 18 to Pin 21, Pin 18 to 24 and Pin 21 to 24 should indicate an open circuit".
My tests reveal:
Pin 12 to Pin 18
Pin 21 to Pin 24
I am assuming that there is a mistake in it saying Pin 18 to 21 and it should be Pin 18 to Pin 12. Is this accurate?
But I also am NOT getting a closed circuit on Pin 18 to Pin 24. Ideas of why this would be the case? Is the board different?
Thanks in advance...
Harris
Re: Superboard Assy Manual Test Procedure 2
The Rom sockets and associated circuitry have been pre wired for 2716 eprom's makes it plug and play
