Anyway/ Attached is a disassembly w/comments of the OSI65A monitor as in the OSI400 etc.
Or it would be if it worked ...... so it's here in the text instead
; OSI-65A Source Code (formatted for XA65)
; Converted by Paul Robson (paul@robsons.org.uk)
CurrentAddress = $FC ; Working address
CurrentData = $FF ; Data to be stored at working address
; (note $FE is not actually used)
CPU_Y = $129 ; Registers that are copied into the 6502 when Go is executed
CPU_X = $12A
CPU_A = $12B
CPU_Status = $12C
CPU_SP = $12D
CPU_PCTR_High = $12E
CPU_PCTR_Low = $12F
NMI_Routine = $130 ; 6502 Interrupt Vectors.
IRQ_Routine = $1C0
ACIA_Control = $FC00 ; 6850 ACIA Control (Write)
ACIA_Status = $FC00 ; 6850 ACIA Status (Read)
ACIA_Data = $FC01 ; 6850 ACIA Data Registers
StackLow = $26 ; Stack starts at $126.
.org $FE00 ; Note, ROM multiply imaged at $FE00 and $FF00
; Read ASCII Character into A from ACIA and Echo it
InputCharacter
lda ACIA_Status ; Put Receive Data Register Full (Bit 0) of ACIA Status into C
lsr a
bcc InputCharacter ; Wait for the Input Character to be ready
lda ACIA_Data ; Read the character from the TTY Unit
and #$7F ; Drop the parity bit, now standard ASCII.
; Print Character in A via ACIA
OutputCharacter
pha ; Save so A is preserved by this routine, also for Input Character.
WaitTDREFlag
lda ACIA_Status ; Put Transmit Data Register Empty (Bit 1) of ACIA Status into
lsr a
lsr a
bcc WaitTDREFlag ; Wait until the TDR is clear so we can send the character
pla ; restore A
sta ACIA_Data ; and write to the TDR
rts ; and return
InputHexDigit
jsr InputCharacter ; Read a character.
cmp #$52 ; if it is an "R", restart the monitor
beq ProcessorReset
cmp #$30 ; must be in range 0-9, A-F
bmi InputHexDigit ; is < "0"
cmp #$3A
bmi ExitInputHexDigit ; if < "9"+1, exit with lower 4 bits
cmp #$41 ; fail if < "A"
bmi InputHexDigit ; fail if >= "G"
cmp #$47
bpl InputHexDigit
clc ; adjusts it so the lower four bits are correct e.g. $41 => $3A
sbc #$06 ; (sec ; sbc #$07 is clearer !)
ExitInputHexDigit
and #$0F ; make a valid four digit value
rts ; and return
; Processor Reset comes here - Resets the ACIA and get the first command.
ProcessorReset
lda #$03 ; Master reset ACIA, write 0 to CR0 and CR1
sta ACIA_Control
lda #$B1 ; Write %1 01 100 01 to ACIA Control
sta ACIA_Control ; Divide master clock by 16. 8 Data bits and 2 stop bits.
; Transmitting Interrupt Enabled. Receive Interrupt Enabled.
cld ; Make sure we are in Binary Mode.
; Get the next command.
MonitorStart
sei ; Disable Interrupts
ldx #StackLow ; Set up the Stack
txs
lda #$0D ; Print Carriage Return and Line Feed
jsr OutputCharacter
lda #$0A
jsr OutputCharacter
jsr InputCharacter ; Read character from Input Device.
cmp #$4C ; (L)oad Command
beq LoadProgram
cmp #$50 ; (P)rint Command
beq PrintMemory
cmp #$47 ; (G)o Command
bne ProcessorReset
; (G)o command. Read the Registers from the end of page 0 into memory, then execute it using
; an RTI to load PCH/PCL/Status.
ldx CPU_SP ; Execute the go command - load Registers from memory.
txs ; Load Stack Pointer
ldx CPU_X ; Load X and Y register
ldy CPU_Y
lda CPU_PCTR_High ; Push PCTR, High first
pha
lda CPU_PCTR_Low
pha
lda CPU_Status ; Push status
pha
lda CPU_A ; Get accumulator
rti ; and start from wherever.
; (L)oad command. Reads 4 digits in as the start address, then reads data into consecutive
; bytes using each subsequent 2 hex digits.
; Exits using the "R" code in the Input Digit Routine.
LoadProgram
jsr BuildAddress ; Read 4 hex digits to make an address
ldx #CurrentData-CurrentAddress ; Read into Current Data
ldy #$00 ; Clear Y.
LoadAddressLoop
jsr ReadByteIntoMemory ; Read 2 hex digits into Current Data
lda CurrentData ; Read the byte that was read
sta (CurrentAddress),y ; Store at the current location.
iny ; Go to next byte
bne LoadAddressLoop
inc CurrentAddress+1 ; If Y overflows increment the MSB of the Current Address
clv ; ... and go round again ... why not BRA ?
bvc LoadAddressLoop
; (P)rint Memory. Gets 4 keystrokes which specify the start address.
; Prints 8 bytes per line with a space after each.
; Terminated by typing any key on the TTY.
PrintMemory
jsr BuildAddress ; Read 4 digits to make an address
ldy #$00 ; Clear Y.
PrintLineLoop
ldx #$09
lda #$0D ; Print a carriage return.
jsr OutputCharacter
lda #$0A
jsr OutputCharacter
PrintDataLoop
dex ; Done 8 of them
beq PrintExitCheck ; if so, check if a key has been pressed, if not loop back above.
jsr PrintCurrentAddressData ; Print byte at (current address),Y
bne PrintDataLoop
inc CurrentAddress+1 ; Adjust MSB if overflowed LSB
jmp PrintDataLoop ; and keep printing data
PrintExitCheck
lda ACIA_Status ; Check Bit 0 of Status (Receive Data Register Full)
lsr a
bcs MonitorStart ; If it is set, then a key has been pressed, exit printing.
nop
bcc PrintLineLoop ; otherwise go do another line.
; Read a byte into memory from the keyboard at CurrentAddress+X
ReadByteIntoMemory
jsr InputHexDigit ; Read the upper hexadecimal digit.
asl a ; move it into bits 4-7.
asl a
asl a
asl a
sta CurrentAddress,x ; save it at the required address
jsr InputHexDigit ; Read the lower hex digit
clc ; Make it into a byte
adc CurrentAddress,x ; (could have done OR here)
sta CurrentAddress,x ; and update it
rts ; and return.
; Read a 4 digit hexadecimal world into CurrentAddress, CurrentAddress+1
BuildAddress
ldx #$01 ; this makes the effective address read CurrentAddress+1 e.g. high byte
jsr ReadByteIntoMemory ; Read Address High Byte in.
dex ; now point to CurrentAddress
jsr ReadByteIntoMemory ; Read Address Low Byte in.
rts
PrintHexDigit
clc ; make it $30-$3F
adc #$30
cmp #$3A ; is it $3A+ (e.g. A-F)
bcs PHDIsAToF ; if so, adjust it, if 0-9 just print it.
PHDOutput
jsr OutputCharacter ; print the character out.
rts
PHDIsAToF ; it is A-F
adc #$06 ; correct the ASCII
bcc PHDOutput ; and print it.
; Print Byte at Current Address followed by Space.
lda (CurrentAddress),y ; Read current byte
and #$F0 ; Get the upper 4 bits
lsr a
lsr a
lsr a
lsr a
jsr PrintHexDigit ; and Print them.
lda (CurrentAddress),y ; Read the current byte again.
and #$0F ; Get the lower 4 bits
jsr PrintHexDigit ; and print them.
lda #$20 ; print a space.
jsr OutputCharacter
rts
.byte $40 ; junk
.byte $9d
.word NMI_Routine ; 6502 Vectors. The ROM is at $FExx and $FFxx
.word ProcessorReset ; so these function as the standard 6502
.word IRQ_Routine ; Reset and Interrupt vectors.
