WP-6502 V1.2
WP-6502 V1.2
Post by lowrybt1 »
I have a copy of WP6502 v1.2 up and running on diskette but can't final the manual for it. Does anyone have a lead on where I might find the manual for version 1.2?
Thanks.
Re: WP-6502 V1.2
I can't find a manual for v1.2, but I have scanned the v1.3 manual in the software section:
http://osiweb.org/software/wp6502/wp650 ... manual.pdf
There is a section describing the differences between v1.2 and v1.3, and there are not many.
Mark Spankus has an 8 inch disk image, and Mike made a 5.25" version from it, also in the software section.
BTW, it would be awesome if you are able to create a disk image of v1.2.
Re: WP-6502 V1.2
Post by lowrybt1 »
I think Mark's 5.25 image is of version 1.2....
