Building the KLyball 610
I too picked up a 610 replica and a pair of data separators from Grant and am going to use them to add a floppy drive interface (and optionally, RAM) to my recently acquired C1P. The second separator will be used to add a different floppy drive to my C1PMF, hopefully restoring it to full functionality. (but that is another thread).
I am not currently planning to populate the RAM portion of the board, instead opting to employ some sort of RAM/ROM board.
Here is my progress so far:
Re: Building the KLyball 610
Here is my parts list, complete with links where to buy components.
610 Parts List.xlsx.zip
Parts List for 610 and Separator
(27.02 KiB) Downloaded 988 times
Here are two handy chip placement guides.
610 LayoutSml.jpg (239.49 KiB) Viewed 16447 times
This one is courtesy OSI.
610 Chip Layout.jpg (232.6 KiB) Viewed 16460 times
UPDATE: revised color PCB layout file; added RAM chips and jumpers
Thanks Jeff!
Here is info on setting the jumpers for Single or Dual sided floppies:
610 FloppyJumpers.jpg (205.02 KiB) Viewed 16447 times
Im not sure about X5-X14. Can anyone in the know verify this jumper for double-sided?
Also, R7 is 1K ohms.
Today I finished off the board (except for the floppy disk separator board) and tested it with 4K of RAM. I plugged it in and it fired up beautifully!
Here is what I was greeted with when I turned it on:
Now I have to build the separator and acquire a floppy. I have purchased this drive from eBay, but it hasn't arrived yet. It should arrive next week.
Hopefully I will be able to get it going!
Great progress Jeff! This is so cool!
The parts for my 600 board are slowly coming in. I should just have spent the money and gotten everything form Digikey, but I've tried to keep the cost down (fixed income and all :( ) and ordered a few things from the far east (like the Cherry key switches).
@Bill, well look at it this way, you can savour the project longer ;-D
Looking good.
I think R20 could be a miss print, as I needed to change it to 1k to get the timing signal correct.
Can anyone with an actual OSI 610 confirm the value of R20?
Today I made the electrical adjustments on the 610 so support reading and writing to the floppy drive. I figured I would post the procedure so that the information is central for future builders.
R18 TX Clock
Remove floppy-disk cable (J3).
Input of scope to pin 13 of U68.
Adjust R18 for a positive pulse width of 400nSec +- 50nSec.
R18 Adjustment.jpg (101.5 KiB) Viewed 16355 times
R9 TX Data
Input of scope to pin 12 of U68.
Adjust R9 for a negative pulse width of 400nSec +- 50nSec.
R9 Adjustment.jpg (104.79 KiB) Viewed 16355 times
continued in next post...
