Word Wizard 3 Premier Publications
The Word Wizard 3 bin I uploaded derives from a UK101 cassette version - hence what may seem an odd size. Not sure if a ROM version was released ?
Back in in the day I had various BASIC and MC programs in ROM on expansion board with associated USER routines called from BASIC and MC to move these to the required locations and set pointers etc to run them. Fortunately a few of these ROMs have survived whereas the cassettes have been lost. The WW3 I had saved in ROM.
(Anyone have Sargon Chess ??)
Locates @ $0240 to $0D90. $0250 Go. I believe the original locations.
Requires BASICinROM and can run on 502 also with some easy Kybd, Screen and ACIA changes etc.
Supports Serial and Parallel printers PIA @$F600 OKI Microline 80 :)
Updated:29/6/16
OSI600 and 502 versions to follow...
WW3_UK101_Fix.zip
(6.47 KiB) Downloaded 970 times
Pernod
Re: Word Wizard 3
Post by Pernod »
Thanks for clarifying the source of the Word Wizard image. I should be able to get this running in MAME with the information provided.
Is the image as released, ie. did it originally load from cassette at $240 and run from $250, or has it been modified in any way?
MAME developer, mainly 70's/80's 6502 8-bit machines
Hardware: BBC Micro
Re: Word Wizard 3 Premier Publications
I wonder if it could be re-located to run in ROM, or does it mix data and code?
Should be possible with a tweak Bill. Do you have an ROM address in mind ?
