560Z Build thread
Re: 560Z Build thread
Post by glitch » Fri Feb 24, 2017 1:46 pm
I got my 12-bit memory board up and going last night. It's got a 12-bit lamp register on it as well, addressable at any byte location in the 64K address space. I'll do a separate writeup on it in another thread.
Tracking says the 74LS125s should be in today, so hopefully I can at least get the porthole functionality tested.
Post by glitch » Sun Feb 26, 2017 3:34 am
IT LIVES!
I spent most of today hacking on the 560Z board. I got the 12-bit porthole going first, took a bit as the manual doesn't tell you that you need IC CC installed if you want to be able to write to the 4K exposed in the porthole. After that, I plugged in a Z80 and tried to get it running the test code in the manual. Turns out I had a dud Z80 :) With a good one installed the test code ran no-problem, as did a little hand written code to push data to the lamp register on the new memory board. I plugged in an IM-6100 and pretty much determined that at least the first one I tried is dead. I'll recheck the soldering on it later -- it's stuffed into a machine pin socket and soldered in, since half of the legs were rotted off by that corrosive black foam everyone loves so much.
Anyway, the second IM-6100 works! And the 560Z board works! And the 12-bit RAM board works! I made a (low-res, poorly focused) video with our old digital point-n-shoot:
https://www.youtube.com/watch?v=ZYbGXHJST8U
The IM-6100 is running a little loop that increments the accumulator and stores it to the lamp register. Storing of course clears the accumulator, but I have the lamp register mapped over RAM, so I just read the value back out of it. My first foray into PDP-8 code, it's certainly different, but it's still just machine code. Very happy that this seems to be coming fully together! Now if only I could find more IM-6100s...I'll test the remaining 3 tomorrow.
Post by Klyball » Sun Feb 26, 2017 11:22 pm
Great Work Glitch,
to save every one having to type it out,Here is the IOT part of the driver asm it has a bit of code i started to handle the memory management,Please feel free to fill in the blanks :)
IOT3400.zip
(2.62 KiB) Downloaded 242 times
Post by glitch » Mon Feb 27, 2017 12:48 am
Had time to do a full writeup on building the 560Z:
http://www.glitchwrks.com/2017/02/26/osi-560z-build
Post by glitch » Mon Feb 27, 2017 4:19 pm
GOOD NEWS, EVERYONE!
I've found a component supplier with IM-6100s in stock! And they have several hundred in the system! They're checking to make sure the items are actually there, and getting me a bulk discount quote put together.
pbirkel
Post by pbirkel » Mon Feb 27, 2017 5:05 pm
Whoot!
Post by dave » Wed Mar 08, 2017 8:29 pm
I'm attaching an IM6100 memory extension app note that may be useful. Also, another appnote on subroutines calls (usually self-modying code) from ROM, which may be less useful on a 560z system with no SYS ROM, but still interesting. I have another I'm trying to scan without destroying on adding a serial peripheral to the 6100.
IM6100 CMOS Processor Memory Extension
ROM Based Subroutine Calls with the IM6100
Post by Jeff » Thu Mar 09, 2017 2:50 am
Great work, guys!
Post by Klyball » Thu Aug 30, 2018 11:03 pm
Just wondering if anyone else got there 560z going and if you wrote any code for the 6100 like mem management or disk support.
Post by glitch » Thu Sep 06, 2018 10:40 pm
I'm dropping off parts at VCF Midwest with another OSI hacker who's working on building up a 560Z. No one else has contacted me with results from 560Z builds, tho. I haven't had much time for OSI hacking lately :(
