Does anyone have a copy of the parts list and build instructions for the Klyball D13 Data separator?
The link here seems dead: viewtopic.php?f=3&t=220&hilit=d13
Much thanks in advance
Parts list and build instructions for D13
Re: Parts list and build instructions for D13
Well if no one comes up with a working link, I have a copy of the file I downloaded on 5/18/2017
Working OSI 600 Rev D with metal case
second 600 Rev D with PIA/Memory board and metal case, working status unknown
Mittendorf board for the Superboard - not working
Could you please upload it to this thread? I'll get the files on the website.
Hi Dave,
djones60 has emailed me the files and I have forwarded them on to you.
Sorry about the delay. Glad Phil beat me to it and forwarded the files on to you !!
* Partlist from file: dataparts.lay6" / 21/04/2015 7:52:20 PM
* Name Value Comment
C1 .1UF
C2 .001UF
C3 .1UF
IC1 7400
IC2 74121
IC3 7406 FUTURE MOTOR CONTROL HEXDOS
IC4 PROTO
R1 560R
R2 1K
R3 1K
TR1 10K
J1 STEP FLOPPY
J2 PIN2 7400
J3 PIN1 7400
J4 FLOPPY READ DATA
J5 JUMPER TO J6
J6 JUMPER TO J5
J7 RECEIVE CLK FLOPPY
J8 RECEIVE CLK DATA SEP
J9 RECEIVE DATA DATA SEP
J10 RECEIVE DATA FLOPPY
J11 DISKCHANGE/READY FLOPPY
J12 READY DRIVE1/DRIVE2
J13 PIN 2 IC3 FUTURE MOTOR CONTROL
J14 MOTOR ENABLE
J15 GND
J16 READY DRIVE1/DRIVE2
J17 READY 8 INCH DRIVE
FOR 5.25 FLOPPY J1-J2,J3-J4,J7-J8,J9-J10,J15-J16
FOR 3.5 FLOPPY J1-J2,J3-J4,J7-J8,J9-J10,J11-J12,J14-J15
FOR DATA SEPARATOR BYPASS J4-J5,J6-J7,J10-J11
C1 .1UF
C2 .001UF
C3 .1UF
IC1 7400
IC2 74121
IC4 PROTO
R1 560R
R2 1K
R3 1K
TR1 10K
J1 STEP FLOPPY
J2 PIN2 7400
J3 PIN1 7400
J4 FLOPPY READ DATA
J5 JUMPER TO J6
J6 JUMPER TO J5
J14 MOTOR ENABLE
J15 GND
Here is the parts placement
- KLyball D13 Parts Layout.JPG (794.67 KiB) Viewed 17125 times
Hello,
Does anyone have the equivalent parts layout for the version 2 D-13?
Crawford
Crawford
Crawford -
Found these back in my files, hope they help!
- Gary
- Gary
- ver 2.png (58.78 KiB) Viewed 13707 times
- D13 V2.jpg (486.34 KiB) Viewed 13707 times
Thanks Gary!
I just figured out that I need to mount the D-13 upside down to work with my 470 board, or mount the female molex .156 connectors on the component side.
-Crawford
-Crawford
