A few years ago, I purchased a pair of Mr. Bachman's mini OSI-300 replicas. One of them I stashed away for future modification, but the first one I built out and have spent a reasonable amount of time playing with.
During DEFCON last year, I was preparing to use it as a makeshift blinkenlights badge, with a 4017's clock line following the flipflop output. During the course of my messing around, I noticed I could no longer load values into memory. I figured "oh, I've fried some logic chip", and replaced the 7 ICs on the board. No change. I found a diode that tested bad, but again, no change in operation following its replacement.
Recently, upon picking up the board again, I noticed that while LOAD doesn't let me write any values into RAM, if I manually pull down the R/W line on the 6264, it will accept deposited values. Curious. I threw a voltmeter at the R/W line during a LOAD, and the voltage stays high.
If I set the address to a location that has a few stray bits in it, and try to load a value of my own, I notice that that the data LEDs dip low for every switch I have set to 0, and stay on for every switch set to 1 but only while the LOAD switch is pushed. They do not persist after the LOAD is finished.
I imagine at least a few folks here have these mini's in their collections. I'm not sure this problem is applicable to original 300's or just mini's. Obviously something has failed on mine, I'm just not sure where precisely. Any ideas what's going on here?
Alright, ignore all that. I found the problem 5 minutes after posting. Apparently I had another failed diode causing all the fuss.
Therefore, let me shift gears. How many of y'all have a mini OSI-300? Anyone make any fun modifications, or try anything interesting with theirs?
I've got one, built another and gave to a friend, and still have one unbuilt board, I think. Haven't done much with mine, I need to change out the LEDs as they're stupid bright. It's fun to poke short programs in and let them run, though!
Josh has his built, and I am in the process of finishing mine up.
It's a nice little board. I'm going with 4 green and 4 red for the data bus,
going with yellow, green, red for the 3 sets of 4 address leds. Pictures to come.
So we will be adding to the small community of owners.
Definitely bringing my Mini OSI-300 to VCF MW along with my 600 REV D
displaying colour. Cheers.
Turning into quite an OSI Junkie (HTFDTH?) Superboard II REV B-40K, 9600b, HC-05 Bluetooth, Superboard II Rev D, C4P rebuild- 502, 542c, 540B.
I'm not sure where Josh got them, i can ask him if he can provide the suppliers name,
but here might be a clue: http://randomvariations.com/ I think he supplied the boards,
not sure if he still has any....
Yeah, they came from Chris at randomvariations -- I think it was a pretty limited run for him, he did supply them with switches on request. I'd message him and find out if he wants to run more, or will at least send you the Gerbers for it.
I will bring mine as well (now completed and working.... not without some issues)
It didn't like the initial 6502 I used and would not play nice with it, but I found one it did like.
also my address line A11 switch is wonky might need to replace it. But yeah it's working and kinda neat.
I'm going to design a 3D printed case for it, that it would slide into. it will be angled, with a flat bottom, and rubber feat. i will post the STL once it's done.
Here is version two of the enclosure.
I have a version three coming which is a tad longer, and includes OSI 300 MINI embossed on the front. Pictures to come, in the mean time:
