Mini OSI-300?
Re: Mini OSI-300?
Post by waltermixxx »
the unit is too small for any meaningful wrist support. :)
It's more decorative than anything... here is a rendering of
the latest (and most likely final iteration) once finalized I will
post the STL on Thingiverse. :)
blue you say?
Re: Mini OSI-300?
I updated the FLICKR ALbum with pictures of the final unit.
the link to thingiverse is here: https://www.thingiverse.com/thing:3707533
pbirkel
Re: Mini OSI-300?
Post by pbirkel »
Nice :-}. Thank you for posting the STL file.
Re: Mini OSI-300?
Please post a picture if you print it...
It’s the best way to say thanks... :0)
I used a little dab of hot glue in the groove at the top of the PC board
After sliding it in, all the way, to secure it in place. Then little rubber feet,
To keep the bottom from sliding.
Cheer!
Re: Mini OSI-300?
So I tried about 6 different 6502 processors, an Josh’s and my 300 board will only work with a Rockwell R6502-11. Any one have luck with another 6502?
The first pick by Z also sports an R6502-11...
Re: Mini OSI-300?
Post by glitch »
Nice work on the little wedge stand!
I think mine also has a Rockwell R6502 in it, I have a bunch of them pulled from various old control systems. It worked fine from the start so I hadn't tried any other 6502s.
gekaufman
Re: Mini OSI-300?
Post by gekaufman »
Case looks great. I hope we can get more boards available :)
Re: Mini OSI-300?
Who all will be at VCF MW in September who has an OSI 300 Mini and would like an enclosure for it, as shown above. I now have blue and silver PLA to print it in. Thinking of printing a bunch for the folks who may not be able to print their own.
Let me know.
to be clear, I'm offering to print one for you for free, if you are at VCFMW and bring your OSI-300-Mini board. :)
just let me know what colour. :)
