New Scan "Understanding OSI Floppy Disk System"
tanteju
Post by tanteju » Mon May 13, 2019 8:57 pm
I've cleaned up some old moving boxes from some decades ago. Was about to throw them unopened away, because do you really need something in a moving box you have not touched for 30 years?
I've found this booklet and scanned it for Dave.
Maybe someone finds it interesting.
Update: Could not upload the 27 MB scan. Fixed.
1982 OSI Floppy Interface.pdf
(1.8 MiB) Downloaded 114 times
Re: New Scan "Understanding OSI Floppy Disk System"
Post by MK14HAK » Tue May 14, 2019 1:58 am
Thanks for this tanteju. However the document is barely readable. Is there an issue with your scanner ...
Post by nama » Tue May 14, 2019 3:25 am
That's great, but as Mike mentioned, quality is lacking.
2P (1mhz 32k) - 502 + 8k + CEGMON + garbage collector fix BASIC, D&N MEM-CM9 + 24k, 540 (mono), D13 + Gotek
Spares - 2 x 527, 1 x 527 [600, 610, D13 boards]
tanteju
Post by tanteju » Tue May 14, 2019 6:49 pm
I see it. That's the result from compression. The original 28MB file is readable.
If someone could download it here https://www.dropbox.com/s/fjs4hxxdm5d38 ... e.pdf?dl=0 and post on the page.
Post by Mark » Thu May 16, 2019 7:30 am
Here is a converted monochrome version about the same size (1.6MB) that may be more legible.
I increased the DPI, sharpened, converted to 1bit & compressed in PDF with CCITT compression, all with the power of XNView. I think it gets a little muddy, but its not too bad for the size.
Thanks to tanteju for the original!
1982 OSI Floppy Interface1.pdf
(1.64 MiB) Downloaded 121 times
Post by waltermixxx » Thu May 16, 2019 8:23 pm
looks great, thanks for the effort. :) definitely a good balace of quality and size. :)
very much appreciated. :)
