I am trying to bring up a D&N Z80 CPU board.
I have no documentation for the board but it does boot to a monitor prompt.
I found a review of the board as PROXY-80 in the InfoWorld Mar 21, 1983 issue.
It uses CPM 2.2 and boots from standard IBM disks.
The board I have had the disk drive cable with it.
The paddle board was modified by cutting two traces and adding a jumper.
They basically cut separated clock and data and substituted raw read data.
The board has an Intel P8272 floppy disk controller chip on it.
So probably IBM format.
It is a serial input for the console.
It uses the same connector configuration for reset and serial input as the OSI-500 and the OSI-510 board.
The dip switches set the baud rate. Switch 7 selects 9600 baud.
I don't know all the monitor commands but found that D xxxx xxxx dumps memory to the screen.
The B command attempts to boot from the A drive after you hit enter.
The monitor is located from FC00 to FFFF in memory.
Any info you have on this board would be appreciated.
OSI Hardware by other manufacturers
Re: OSI Hardware by other manufacturers
Paddle board mod for D+N Z-80
D+N 106 I/O board provides a serial port for OSI using a UART chip.
- D+N Serial board 106 I_O.pdf
- Instruction manual and schematic for D+N 106 I/O
- (6.3 MiB) Downloaded 617 times
Floppy disk controller card made by Science Aztek Inc.
It is only half height compared to regular cards.
This card has an OSI standard 24 pin jack and a long ribbon cable that can be used instead.
I have no documentation for it.
It is operational using the standard OSI output and a set of OSI eight inch drives.
I did not get it working with the red ribbon cable yet.
There may be a jumper or some sort of configuration needed.
D+N BIO-1600 Card
Description from D+N catalog:
The B10-1600 comes bare complete with documentation and MOLEX connectors.
The card combines many features into a single board supporting the following functions:
8K of Memory using 2114W type chips in 2 independent DIP SWITCH selectable
4K blocks. This memory may be used in any unused RAM memory section. An ideal use
is to expand ROM-based computers to their maximum BASIC workspace of 40K. two 16
BIT Parallel input/output ports. One port can be used as a Centronics Parallel printer,
the other as a Diablo Parallel printer port. Both ports may be used as experimenters
parallel l/O ports.
Five RS-232 ACIA serial l/O ports for use as serial printer ports or communication ports.
Supported by OSI software.
parallel l/O ports.
Grafix SEB-3 video card.
Replacement for OSI-540 video card with a built in floppy disk controller.
