C2 Serial Games
C2 Serial Games
Having managed to connect my C2 OEM to a Windoze computer via USB and Putty, I wanted to capture some of the BASIC games I entered into this system back in the day. Note that this is for a *serial* system, no graphics. There is a BASIC version of the David Ahl Star Trek game, along with the companion instruction program. There is also a version of Adventure! I wowed folks at a VCF show some years ago when I had the C2 up and was playing Adventure on it. These are attached here as Windows text files, as captured from Putty. Putty is so much nicer than the Televideo 912 I always used with the OSI...
- ADVENT.BAS.txt
- (25.96 KiB) Downloaded 315 times
- INSTRK_text.txt
- (4.63 KiB) Downloaded 317 times
- INSTRK.BAS.txt
- (6.46 KiB) Downloaded 308 times
- STREK1.BAS.txt
- (19.87 KiB) Downloaded 305 times
Re: C2 Serial Games
Copies of the above with lines squeezed to fit the 71-character OSI BASIC input buffer, by removing the spaces before and after line numbers, and replacing the first occurrence of PRINT on any line with a question mark.
- ADVENT71.BAS
- (23.92 KiB) Downloaded 302 times
- INSTRK71.BAS
- (5.79 KiB) Downloaded 299 times
- STREK171.BAS
- (18.32 KiB) Downloaded 296 times
