Whoo hoo I came across a 630 board , added the chips to the 600d cut the 2 traces and added the jumper and its outputs b/w composite, and looks like the rgb signals are good just need to make a cable to fully test ,but I see no reason it won't work.
Here is the interesting part ,if you look at the bottom right corner there is a space for 5 chips a crystal and support components. I haven't 100% confirmed the layout but seems to be identical to the 540b color composite output circuit. I wonder why its not mentioned anywhere that I have seen or even on the schematic. The schematic parts layout is identical minus the undocumented components.
I have started on the replica to complete the 600,610,630 set.
Elusive 630 board
Elusive 630 board
Re: Elusive 630 board
Looking forward to seeing the colour!
Please take a picture of the board as it one of the long missing images from my OSI hardware board list!
Thanks!
Thanks!
Boy, this brings back memories from 1981+ when I desperately wanted to find a 630 board and add color to my C1PMF. I thought it was true vaporware.
I can confirm that the missing chips do correspond to sheet 6 of the 540B schematic and the circuit inputs are connected .
Can anyone confirm the color video RAM memory location for the 600D?
Normal 1K screen memory is located at D000 through D3FF. Is the 4bit color RAM at D800-DBFF or D400-D7FF or ???
Thanks!
Thanks!
D400-D7FF 1024 offset to video ram
Don't know if this is of any use. I made it while trying to sort out my colour board... sorry for the roughness.
that helps.
I am trying to verify U72 control port. From the OSI schematics it looks like:
it differs a bit from your notes. I was just verifying WinOSI handles this correctly.
Also has anyone run across any C1 programs that use color? Thanks!
that helps.
OSI 600D U72 74LS174 Hex D-Flip Flop
D0 = (pin 7) /32
D1 = (pin 5) Color Enable
D2 = (pin 2) BK0
D3 = (pin 12) BK1
D4 = (pin 15) DAC Disable
D5 = (pin 10 NC?)
