This is the manual from the final (1.3a) version of WP6502. 1.3a was quite different from 1.3. I don't know why it wasn't called 1.4, it just wasn't.
Scanned as black/white only, to (a) keep the file size down, and (b) hide stains on the covers.
The manual is 8.5 x 5.5 inches, all on plain paper except for the front and back covers, which are cardboard, with the outside surfaces (only) having a glossy finish. It's held together by two staples, but with three holes punched near the left margin so it can be put in a binder. The top-right and bottom-right corners of the manual (looking at it from the front) have rounded corners.
PDF page 45 is a loose piece of paper that was placed just inside the back cover of the manual. The change "that will be unique to your system" referred to was to set the value of the variable HS equal to the size of the hard disk "system" (partition) that the program was installed in.
WP6502 Operations Manual Version 1.3a
- WP6502 Manual.pdf
- (1.06 MiB) Downloaded 224 times
