OS65D AC for C4P
OS65D AC for C4P
Post by lowrybt1 » Mon Nov 23, 2015 3:38 am
I'm restoring a C4PMF and have a question:
* Did OSI ever produce the version of OS65D specifically designed for controlling/interfacing with the BSR AC control modules?
* If I were to scrounge up an old BSR AC module, where could I find detailed instructions on how to interface it with the C4P?
Thanks, Tom
Re: OS65D AC for C4P
Post by Klyball » Wed Nov 25, 2015 2:29 am
Hi Tom
i believe the CA-25 Security and AC remote interface was what would have been used, the c4p manual has some relevant material
check through the journals also for some goodies.
interfacing to the head end cards is where youll find your info
Grant
Post by MK14HAK » Wed Nov 25, 2015 3:43 am
There is third party software available for the BSR X/10 Home Control system at least. C4 5" I believe.
I wonder if Grant will clone these controllers if there is interest.
Post by Mark » Sun Nov 29, 2015 8:47 pm
I recently added X10 decoding to WinOSI, and have seen working OSI X10 interfaces back in the day. (Actually I still have all the parts to make a C4PMF interface to the powerline.) The interface used by OSI is not X10 compatible, rather it interfaces to the ultrasonic input on the old wood-grain BSR x10 consoles. OSI simulates the Ultrasonic remote!
One of the OSI demo disks had an AC demo, and there were at least a couple attempts at commercial software. See http://osi.marks-lab.com/software/misc.html
Here are the notes I have for decoding the OSI X10 signal.
The original BSR X10 Home control consoles had an ultrasonic transducer which received messages from the ultrasonic handheld remote control.
You set the X10 home code on the console. The remote sent sonic unit and control codes. The OSI worked with a modified console. An opto- isolator, resistor and RCA plug were added to the ultrasonic input of the console.
BSR X10 Ultrasonic Wireless remote protocol (Used by OSI 540 board)
The 40KHz signal was used with a push button wireless (ultrasonic) remote
Since base has house code, it is not sent by remote
1 complete message every ~100 ms; there are 13bits, each bit is 8ms long
logic 1 is 4ms of 40Khz, 4ms silence
logic 0 is 1.2ms of 40Khz, 6.8 ms silence
13bit handheld remote message definition:
SOM 5-bit binary code Inverted code EOM
|# | D4| D3| D2| D1| D0|!D4 |!D3|!D2|!D1|!D0|###|###|
SOM (start of message) = 4ms on, 4ms off (normal '1')
EOM (end of message) = 16ms "on" burst
Cordless controller push-button code translation table.
 	               5-BIT BINARY CODE
UNITCODE 	D4    D3 	D2 	D1 	D0 	DECIMAL EQUIVALENT
01  			0 	1 	1 	0 	0 	12
02  			1 	1 	1 	0 	0 	28
03  			0 	0 	1 	0 	0 	04
04  			1 	0 	1 	0 	0 	20
05  			0 	0 	0 	1 	0 	02
06  			1 	0 	0 	1 	0 	18
07  			0 	1 	0 	1 	0 	10
08  			1 	1 	0 	1 	0 	26
09  			0 	1 	1 	1 	0 	14
10 			1 	1 	1 	1 	0 	30
11 			0 	0 	1 	1 	0 	06
12 			1 	0 	1 	1 	0 	22
13 			0 	0 	0 	0 	0 	00
14 			1 	0 	0 	0 	0 	16
15 			0 	1 	0 	0 	0 	08
16 			1 	1 	0 	0 	0 	24
	               5-BIT BINARY CODE
COMMAND			D4	D3	D2	D1	D0	DECIMAL EQUIVALENT
ALL OFF			0 	0 	0 	0 	1 	01
ALL LIGHTS ON		0 	0 	0 	1 	1 	03
ON   			0 	0 	1 	0 	1 	05
OFF   			0 	0 	1 	1 	1 	07
DIM   			0 	1 	0 	0 	1 	09
BRIGHT   		0 	1 	0 	1 	1 	11
The 40KHz burst is controlled by bit 3 of $DE00 of the 540 video board. 1=enable 40Khz AC Home control output (used as 1 bit serial stream)
