Paddleboard and separator....again
Post by nama » Tue Jul 22, 2014 8:08 am
Hi everyone,
This is my second attempt at designing a new paddleboard + data separator.
I decided to make this one a little simpler and remove the motor control circuit and just focus on the basics.
I’m putting this out there so that you can all help me critique it, and hopefully check my layout. I really want to get this right the first time so I don’t have to make multiple revisions. The basic design for the separator was borrowed from the Aardvark Journal v2n6 from February 1982.
(N.B I still need to layout the PCB, and rename some of the components)
Here are the specs:
- Designed for 5.25” and 8” drives. The connections for the 5.25” were reverse engineered from the OSI A13 paddle board. The 8” drive connections were given to me by Mike as I don’t have an 8” drive setup. (Please note that the drive connectors are designed to be mounted on the solder side of the board, so the PCB layout will show them mirrored)
- JP1 sets Shugart & PC standard 5.25” drives
- JP4 & JP5 disable the data separator section for those who already have the data separator.
- TP3 is a test point for setting the timing via R1.
- TP1 & TP1 make a jumper that need to be shorted when setting the timing.
- Timing adjustment components are on the extreme right of the PCB for easy access when the board is installed in an OSI C2 or C4, and possibly others.
If you are willing to help, I’d really appreciate it if you could have a look over the layout. I'm still learning so be gentle.
Love to hear back from you all.
Re: Paddleboard and separator....again
Post by nama » Thu Aug 07, 2014 3:06 pm
No takers?
No one wants to double check my schematic?
Boo hoo, so sad :-(
P.S. if you can't see the complete schematic in the browser, try dragging the image to your desktop (or saving it to your HD by other means). You should then be able to view the whole thing.
Post by BillO » Sat Jun 13, 2015 4:56 pm
Nama, did you ever build or test one of these?
