Building the KLyball 600D
Re: Building the KLyball 600D
Post by BillO » Tue Jun 23, 2015 8:04 pm
Hi Grant,
Yes, I see your note now. RTFM!
As for the video, the buffers are 8T28s and I have rechecked the memory section 3 other jumpers (R32 to Vcc, vias under U56 to connect pin 2 of U57 to J3 pin 8 and pin 15 on U59 to adjacent via).
Would these cause the characters to display backwards or are there other jumpers to configure??
Post by Klyball » Tue Jun 23, 2015 8:30 pm
I will confirm that these are the correct connections when I get home, I can't remember what problems it caused without the connections . But when I brought the board up I got video fixed first then memory and finally the lifted pin to boot. I think I would have remembered if it was backwards, but short term is failing me :?
Post by BillO » Tue Jun 23, 2015 11:08 pm
I got the video working. It was the character generator. I found a different file, burned it, tried it and we're all good now!
Just got to get the serial working. When I type SAVE, it goes into limbo.
Post by Klyball » Wed Jun 24, 2015 12:22 am
J3 on revision D needs to be configured, with out the baud divider connected there is no tx/rx clock to the 6850
Post by Jeff » Wed Jun 24, 2015 2:59 am
BillO wrote:I got the video working. It was the character generator. I found a different file, burned it, tried it and we're all good now!
Bill, can you post the file, so there is no confusion? Thanks!
Post by BillO » Wed Jun 24, 2015 4:46 am
@KLyball - Thanks Grant for posting that. I finally figured it out after looking through the schematic for a while. Too long, really. Ahhh...
Is that new (600D) Superboard II doc available on-line somewhere? It would be nice to have a copy.
@Jeff. The character generator file that worked for me is attached below.
CHARGEN.zip
Character Generator ROM
(1.18 KiB) Downloaded 114 times
Post by Klyball » Wed Jun 24, 2015 4:58 am
Post by BillO » Wed Jun 24, 2015 12:20 pm
Thx Grant!
Post by BillO » Wed Jun 24, 2015 5:10 pm
My 600D is up and running at 100%! Thanks everyone for your assistance on this!
Now, here's more good news. My memory expansion board functions 100% too on this mainboard. So that project can now continue.
BTW, what baud rates do you folks use and what do you use for end of line and character delays for text transfers?
Post by Jeff » Wed Jun 24, 2015 10:58 pm
9600 no delays
