Connecting a USB TTL Device to a Superboard II
Post by Jeff » Sun May 24, 2015 2:37 am
The Superboard does not have an RS-232 interface by default. In todays world, the better interface is USB. So I went about connecting a USB - TTL device so I could transfer data from my PC to my Superboard.
Here is the USB-TTL device, available on eBay for about $7.00
UART Device.jpg (79.69 KiB) Viewed 2761 times
Re: Connecting a USB TTL Device to a Superboard II
Post by Jeff » Sun May 24, 2015 2:43 am
I wanted the device to be separate from the Superboard and connect by a cable. J3 was the perfect candidate. TX Data and Ground are already present and there are 3 unused pins. I selected Pin 12 for +5V and Pin 8 for TX DATA, and installed some jumpers on my Superboard.
Here is the power jumper.... I placed it on the bottom side of the motherboard.
Power Jumper.jpg (69.43 KiB) Viewed 2760 times
And the Jumper for TX Data... neatly tucked under IC chips so it stays in place!
TxData Jumper.jpg (184.13 KiB) Viewed 2760 times
Here is the circuit diagram. Note that TX goes to RX, and Rx goes to TX.
Circuit Diagram.jpg (28.13 KiB) Viewed 2760 times
The other short blue jumper is the clock jumper that I used to speed up the ACIA to 9600 baud.
One last step is to download the drivers for the USB - TTL device and install them on your PC.
Enjoy!
Post by BillO » Sun May 24, 2015 8:10 pm
Jeff, Isn't that device powered from the USB?
The ones I use are:http://www.ebay.ca/itm/201332938880?_tr ... EBIDX%3AIT
If that is the case, it might not be a good idea to connect the 5V from it to your computer's Vcc.
Post by Jeff » Mon May 25, 2015 4:52 am
Hi Bill,
I tested the Vcc and Gnd Pins with the unit just connected to the host computer, and there is no voltage across them. Basically, the unit provides a USB connection for a device, and needs to be powered by that device. (But your concerned are much appreciated!)
Here is the circuit info sheet that came with it.
Device Info.jpg (93.46 KiB) Viewed 2745 times
Post by BillO » Mon May 25, 2015 12:17 pm
Ah, okay. I see there is a jumper to the right of where it says 'FT232BM' that connects the USB power. As long as that is not closed you will be fine.
Sorry for the alarm Jeff.
Post by MK14HAK » Tue May 26, 2015 12:46 am
Jeff whats the link to yours please?
Post by Jeff » Tue Jun 02, 2015 4:23 am
Here is the link to the USB-TTL device I used. Its a bit more than others, but has a more compatible connector on it.
http://www.ebay.com/itm/371288534219?_t ... EBIDX%3AIT
