OSI C3A (finally) Booting from Floppy
john
Post by john » Mon Nov 30, 2015 2:42 pm
My C3A system has finally booted from the floppy disk!!
I used my homebrewed 6502 logic analyser to find it was stuck trying to move the head to track zero.
Then used my saleae logic analyser on the 470 disk controller find the "step" signal was toggling
on/off at the PIA but not on the 50 pin disk interface. That lead me right to the burned out 7417 hex buffer that
drives the step signal.
I just happened to have a 7407 in the junk bin and it's a pin compatible alternative for the 7417.
With that installed the system booted from floppy. Then I realized how little I remember about how
OS65D works. I'm going to have to get out the manual.
I can now go thru my pile of diskettes and find out what I have. I know a few folks were waiting for a copy of my
FORTH diskette. As soon as I figure out how OS65D works and can copy it I will share.
john
C3A-8P 510CPU, 470Disk Controller, 527 memory (3x=48k), dual 8" floppy
Re: OSI C3A (finally) Booting from Floppy
Post by MK14HAK » Mon Nov 30, 2015 10:46 pm
Great to see you have this booting John.
I hope you have equal success reading your floppies.
Post by dave » Tue Dec 01, 2015 1:09 am
Great to hear!
Also, it would be awesome if you are able to make images of the Pegasus software disks, particularly FBASIC.
