Power Supply - C4PMF with additional 527 board
Post by lowrybt1 » Sun May 22, 2016 5:10 pm
Question -- I'm getting ready to add a second, fully-populated 527 board to a C4PMF to achieve 48K. Does anyone know if the two PSU's that came installed with the original C4PMF's provide sufficient current to power all that RAM?
Re: Power Supply - C4PMF with additional 527 board
Post by BillO » Sun May 22, 2016 11:05 pm
What are the specs on the transformers?
What are the pass elements in the regulators?
How much current does a fully populated 527 board draw?
We should be able to figure this out.
Post by lowrybt1 » Mon May 23, 2016 5:07 am
I get the specs on the transformers. One of them is definitely committed to just the 527 board and the other one supplies the backplane -- and through the backplane both the 505 and 540 boards.
A 2114L draws a max of 100ma. With 48 2114's on a fully populated 527 board, the theoretical max current could be something like 4.8A?!
Post by BillO » Mon May 23, 2016 12:12 pm
Call it 5 amps to account for any other logic on the board.
I'd say, in order to keep things reasonably cool you would need 7 amps reserve on that power supply to add another 527 board.
Post by Jeff » Thu May 26, 2016 4:42 am
Originally my C4PMF had two 5 amp power supplies to power the two 527 boards in the system. One 5 amp for the CPU and the first 527, and another 5 amp for the second 527 and the view board. HOWEVER, I replaced the original power supplies with a new, 10 amp regulated switching one that is tremendously more reliable, and cooler. It was not expensive.
Here is a photo:
C4P Power Supply.jpg (153.21 KiB) Viewed 8487 times
