WP-2 WP-3 Ohio Scientific Word Processors
Post by MK14HAK » Mon Sep 19, 2016 10:21 am
I have managed to create a working image of WP-2 the early OSI Word Processor from dumps sent to me by Mark Spankus.
Unfortunately the WP-3 disk dump has a corrupt track 6 sector 2. It looks like the disk was booted on a system with less than 24K working memory. The Bexec* loads this sector at $5100 and modifies a few locations then saves back to disk. This sector has been overwritten with $51...$52...
Anyone have WP-1B or WP-3 manuals or disks ?
WP-1B integrates with the Assembler offering auto line numbering, a full line editor and global find and replace.
WP2 boot.jpg (9.85 KiB) Viewed 1929 times
from The Second Book of OSI:
WP2 SBOSI.jpg (205.5 KiB) Viewed 1929 times
WP2.zip
WP2.1 update
(91 KiB) Downloaded 113 times
Re: WP-2 WP-3 Ohio Scientific Word Processors
Post by nama » Mon Sep 19, 2016 10:04 pm
Great news about WP-2
Not so great about WP-3
Thanks for your efforts.
Post by dave » Tue Sep 20, 2016 11:57 pm
Thanks, mike! I had the manual but thought I already had a scan of it. I just scanned it and added your ZIP file and the manual in the software section.
Post by MK14HAK » Wed Sep 21, 2016 2:41 am
Great.Thanks Dave. Will be nice to get WP-1B and WP3 editor images up sometime.
WP-1B integrates with the Assembler offering auto line numbering, a full line editor and global find and replace. WP-3 was preferred over WP-2 for its friendlier editing and extra word processing features.
Brings back a few memories, I had both versions and the WP-3 manual back in the day using Microline 80 printer.
Post by MK14HAK » Fri Sep 30, 2016 6:40 am
The C4_WP2 uploaded earlier uses $3179 as its workspace start. $3279 or $3A79 is normal for other 5" systems.
Indirect file usage will allow you to load and edit Assembly language and BASIC source files from these disks with WP2. I have added WP2.1 that modifies the indirect file markers in WP2 to be compatible with 65D markers to allow this method of loading. Also added the DOS GO $xxxx command back at the expense of the X16OUT routine. (WP2.1 added to earlier zip)
WP2 allows Edit n for line recall and similar in-line editing as for DOS3.3 editor , plus global search/replace, move, merge etc.
Indirect file usage: Edit Assembler or BASIC source files in WP2.
BASIC
POKE 9368,XX:POKE9554,XX:REM XX is page boundary e.g $5000 = 80 for indirect file. 65D BASIC.
POKE14646,91:POKE11667,XX:REM 65U BASIC
LIST[ (LIST+SHIFT+K) lists source to indirect file location.
] (SHIFT+M) closes output to indirect file.
ASSEMBLER
:@2552/80 50 ;set page eg $5000 for indirect file start.
.P[ (P+SHIFT+K) lists source to indirect file location.
.] (SHIFT+M) closes output to indirect file.
Boot WP2.1 modified version.
.WH5000 ;set page eg $5000 for indirect file start.
.CTRL+X move you indirect file to WP2 workspace for easy editing.
... any interest in C1 version ??
