Sideburn wrote: ↑Fri May 24, 2024 4:42 pm
It’s composite. And it was difficult to find an lcd that would sync.
Ended up using a 90s lcd tv. I just found out about the rgb2hdmi and will be using that on an Atari 8 bit to laptop conversion.
That 8 bit project sounds like one I'd follow
There are lots of options for the 8bit to output to other displays, such as Sophia, UAV, UGV and VBXE/VBXL. There is another, but the name escapes me.
I personally use VBXE on a couple of mine (A 65XE and an 800XL) and the output is superb, though I do use it via SCART being in the UK.
ronin47 wrote: ↑Sat May 25, 2024 9:35 am
I didn’t know there were so many options. I use a CRT on my desktop retro machines (Atari, commodore, Amiga) but the next laptop conversion will be a 65XE PAL Arabic one I picked up on eBay. I figured the Arabic keys and PAL would make it a bit unique. For this I can use a modern LCD so I got a 4:3 11” monitor off Amazon and it works through the composite A/V but I just ordered the Rgb2hdmi / LumaCode and GTIAdigitizer off Copperdraggon in Australia.
I was surprised when I cracked open the new lcd monitor to find the the whole thing is hot glued together inside. No screws. The lcd panel is just covered in gobs of hot glue as well as the speakers. It’s going to be a challenge pulling that lcd panel out of there.
I’m off to a slow start because the Superboard project was pretty exhausting
Yep, the 8 Bit Ataris are very well served for video upgrades, you're spoiled for choice.
Also, they can output (mostly) composite as stock, and S-Video with minor mods.
Yeah my daily use Atari is a 130xe, with Fujinet, 1050, 1020, connected to my original Amdek Color I monitor I had as a kid over composite.
Looks like that’s a Sega Saturn adapter for the XEGS. Well I went for the LumaCode method for the 65XE. I’m going to have to desolder the GTIA.
Now this video talk is making me try to remember if I tried using a composite video to HDMI on the Superboard II.
I’m pretty sure I did try one of those A/V to hdmi converters and had no luck. My short term memory must be going out. I could back track through the posts on here and see if I mentioned it.
I know I had a heck of a time getting anything to sync to it other than a CRT.
A pixel perfect to hdmi conversion on the superboard would be pretty cool. I have no idea how you’d pull that off though. Need to tap right in to the video somewhere before the composite conversion happens I suppose.
Sideburn wrote: ↑Wed May 29, 2024 12:14 pm
Can't recall if I tried a composite to HDMI adapter, must revisit as I have a few, such as a cheapo Amazon one and my Retrotink 2x.
All I have is a cheapo composite to HDMI adapter from Amazon. I’m sure I must have tried it. It’s coming back to me. I was trying everything I could at the time when I was sourcing a display for this project.
On the XE, mine is PAL, I’m not going to have any issues with the lumacode digitizer and rgb2hdmi am I ?
Sideburn wrote: ↑Wed May 29, 2024 12:35 pm
Not a question I can answer I'm afraid as 2 of mine have VBXL and the other 2 are standard PAL and use composite.
