I finally just finished my Superboard II to luggable portable conversion. Everything is 3d printed and mostly snap together so no visible bolts (except for the hinge bracket mount bolts on the bottom and the hinges on the front of the display).
Instead of latches to close the display lid I am using powerful magnets below the keyboard surface and inside the display enclosure. Worked out pretty well surprisingly since there’s a pretty large gap of air between them where the space is to allow for the keyboard not to touch the lcd panel.
I had to split it into 4 quarters because my printer only has a 10” build platform but everything is tongue and groove and bolted together.
The board itself also bolts on. Everywhere there are bolts I used threaded inserts to make sure it can stand the test of time disassembling and reassembling.
It has 16 2,000 mah nimh batteries in it that give it a runtime of about 2.5 hours. It’s a power hog!
There’s a few issues here and there but overall I am pretty happy with it.
I’ll be making a video demo soon but here are some photos for anyone who wants to have a look
![Smile :)](./images/smilies/icon_e_smile.gif)
